Old 24-Oct-2013, 11:54 AM   #1
rry19
Antenna Suggestions Northeast PA
I have cut the cord about two years ago and have indoor RCA-1450 antennas attached to my three TVs with poor results. I am receiving 2 stations consistently, the rest have signals that come and go. My house has aluminum siding so an outdoor antenna would be needed. I live in a small house in the suburbs so I can mount the antenna around 20ft high on a mast. The other issue to contend with is the terrain, I'm in a valley at the base of a mountain (~600ft) to my north. Would a smaller antenna like the RCA ANT751 be a good bet or should I go for something bigger as well as the best direction I would want to point it at?
http://www.tvfool.com/?option=com_wr...46ae0051d2b01e
rry19 is offline   Reply With Quote
Old 25-Oct-2013, 5:59 AM   #2
Practical and Useful Information.
Yes a ANT751 antenna installed above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , south , north , north east.
Aim the ANT751 antenna at about 186 degree magnetic compass direction.
If the weaker signal strength , WQPX-DT , ION Tv and WSWB-DT , The CW , are not reliably received with No amplifier.
Then re aim the antenna at , WQPX / WSWB at about 50 degree magnetic compass direction.
A amplifier such as a Winegard , LNA-100 'Boost' amplifier , before the splitter can be installed If required.
It is always better to use No amplifier if reception is reliable.
Amplifiers Are Not a --> automatic given.
www.solidsignal.com
www.amazon.com
www.winegarddirect.com
Digital Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do Double Rescan , www.wchstv.com/DoubleReScanAlert.pdf
As always , trees and tree leaves , plants and plant leaves , have Negative Effect on Broadcast Tv Reception
Absorbing , Blocking , Broadcast Tv Reception
Multi-path Reflections bouncing around and disrupting reception.
And so do buildings and other obstructions including your own roof and building.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Last edited by teleview; 31-Oct-2013 at 7:26 AM. Reason: Clarify information and typos.
Old 30-Oct-2013, 1:24 AM   #3
rry19
Extremely Helpful
Thanks teleview for all of the information I needed. I am nearly ready to put everything up but I am left with one more question I hope somebody can answer. Knowing that both the coax and antenna mast must be grounded what is the best way to go about it. I have seen Coax with ground wire together on the same cable in a few stores. Would that work or should/must I keep the coax and ground wires on separate cables.
Old 30-Oct-2013, 1:29 AM   #4
Ground wire with/part of the coax is Ok.
Last edited by teleview; 30-Oct-2013 at 4:47 AM. Reason: Clarify information and typos.
Old 30-Oct-2013, 4:14 AM   #5
Agreed, coax with messenger wire can serve as the grounding conductor for the mast.
You will also want to ground the coax shield, use a grounding block prior to the coax entering the building. A common location for the grounding block is near the existing electrical service were it's a short run to connect to the ground rod.
http://forum.tvfool.com/showthread.php?t=901 (post #20 is a summary)
