Old 28-Feb-2013, 5:48 PM   #1
cheito
TV
Need help whats the best TV converter box for a 70" TV flat HD thanks
cheito is offline   Reply With Quote
Old 28-Feb-2013, 9:24 PM   #2
You provided a Minimum of information.
Is this a Older flat screen Tv with No built in Digital Broadcast Tv Tuner??
What is the model number of the Tv??
Any way , here are the Digital Broadcast Tv Tuners.
http://www.epvision.com.
http://www.channelmasterstore.com/Di...onics_s/37.htm.
More help with reception.
Is this a , house , town home , condo , apartment , mobile home , motor home , or , etc.??
What directions do the , windows , patios/balconies , face??
What floor??
What is the top floor??
Make a tvfool radar plot report with the exact address and make the Tv antenna height 25 feet above ground , if the antenna will be higher then 25 feet above ground then then use that antenna height to make the tvfool radar plot report with.
Old 28-Feb-2013, 9:26 PM   #3
You probably already have one built in
If the TV was built after mid 2007, and has any tuner built in, it should already be fully capable of receiving over the air digital TV signals. This is an FCC mandate that applies to TV's sold in the US.
Most TV tuners default to 'cable' mode which uses a different digital format than OTA digital broadcasts. If you currently have cable service, you'll need to get out the user manual and follow the manufacturer's instructions to re-configure the tuner from 'cable' mode to 'air' or 'antenna'. Typically, once that's done and you have an antenna connected, you'll then need to run a new scan for channels.
If you need help selecting or installing an antenna, please post a link to your TV Fool reception report.
Having said all that, Channel Master offers several options. The CM-7001 is a tuner capable of receiving 1080i, 720p and 480i OTA content. They also offer a couple of tuner/DVR options in the CM-7400 and CM-7000PAL.
http://www.channelmaster.com/Set_Top...e_DVR_s/40.htm
There are other products as well, http://forum.tvfool.com/showthread.php?t=2882.
Old 5-Mar-2013, 12:34 AM   #4
cheito
hi !!!!! thanks for your reply and sorry for the delay and no i havent bought this tv a 70" that i am going to purchase soon i just wanted to get some info. from you guys on what is the best way on what the best 70" model tv there is out there to use with a converter box ??? or not to get me one when i get the tv and if i use the tv without the converter box will i get the same channels that i get with the converter box cause i get all of the channels that i want with it on a regular tv i live in orlando florida thanks
p.s. and what will be the best converter box for this tv 70" if you guys sugest one that will work with this tv thanks
Old 5-Mar-2013, 1:13 AM   #5
Okay, let's try this one more time...
ALL new TV sets sold in the US already have digital tuners installed and do NOT require external converter boxes. Internal digital tuners have been required in all TV sets sold in the US since early 2007 (with only minor exceptions).
BTW, do not confuse TV sets with monitor displays.
