Old 17-Jun-2012, 7:25 PM   #1
notv4me
just installed rca ant751
I only get one channel (spanish)
Here is my location:
http://www.tvfool.com/?option=com_wr...13499e18dd9bcb
Do I need a different equipment?
Please help!
notv4me is offline   Reply With Quote
Old 18-Jun-2012, 1:48 AM   #2
Which channel did you receive?
Did you re-scan, setting the tuner to scan for 'air' or 'antenna', not 'cable' channels?
And, does your TV have a digital tuner? (What's the make and model of your TV?)
Old 18-Jun-2012, 8:40 PM   #3
ALL questions and answers about Broadcast Tv Reception and More.
The Tv/s MUST Scan for the -> Digital <- Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
DO NOT scan for cable Tv channels.
Aim the ANT751 antenna at about 155 degree magnetic compass.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html
If the Tv or Tv,s will not receive the Digital Broadcast Tv Channels here are some converter boxes.
Channel Master has converter boxes , http://www.channelmasterstore.com.
Walmarthttp://www.walmart.com
, has 3 converter boxes.
RCA DTA800B1.
Sunkey ATB150S.
Magnavox TB110MW9.
