Old 29-Sep-2010, 7:24 PM   #1
cw60
Antenna advise make and models if possible
need antenna advise for http://www.tvfool.com/?option=com_wr...a362b8c7073282 My home is a single floor wooden frame house.I have a thin perimeter of tall trees . The antenna will be for one hdtv, a panasonic TC P54G25 plasma. Please include make and model #of antenna if possible. Thanks for any advice
Last edited by mtownsend; 29-Sep-2010 at 10:28 PM. Reason: Fixed link to TV Fool report
cw60 is offline   Reply With Quote
Old 29-Sep-2010, 10:03 PM   #2
Tower Guy
You have stations from multiple directions. There is no perfect antenna. The easy answer is a 7-69 antenna with a rotor.
HD-7694P
HBU-33
Another option is two of these antennas, one aimed at 160 the other at 32 degrees with an A/B switch at the TV set.
Rotors are clumsy, but so are A/B switches.
TVfool also shows 4 LPTV stations. Do you know what programming is on them?
Old 30-Sep-2010, 1:04 AM   #3
cw60
Thanks for the info Tower Guy. Will have to do some checking on the LPstations ,will get back to you later.
Old 30-Sep-2010, 10:13 AM   #4
John Candle
Tv Reception
RTN Retro Tv Network KWCE-LP UHF-27 is a analog transmitter. MyNetwork K47DW UHF-47 is shown both as a analog and digital transmitter. TBN Trinity Broadcasting Network K45IY UHF 45 is a analog transmitter. Unknown programing KBAC UHF 41 is a digital transmitter. I recommend a 2 antenna solution , 2 Winegard HD7695P antennas. And a Radio Shack remote control A/B coax switch box. http://www.solidsignal.com , http://www.starkelectronic.com , http://www.warrenelectronics.com , http://www.amazon.com As all ways , good roof mounts are the Tri-pod mount , the chimney mount and the eave mount. Put the 2 antennas at least 6 foot distance on separate mounts. Point one antenna at magnetic compass 28 and the other antenna at 127 magnetic compass. The 2 antenna solution is the easiest to operate. Read and understand this http://forum.tvfool.com/showthread.php?t=695
Old 30-Sep-2010, 12:15 PM   #5
John Candle
Tv Reception
Or a 1 antenna solution is a HD7695P and a antenna rotor. Channel Master 9521a or a http://forum.tvfool.com/showthread.php?t=460
Old 30-Sep-2010, 3:41 PM   #6
SWHouston
An Old Member
SWHouston's Avatar
How about a Winegard MS-2000
Good Golf, good OTA/HDTV and anything else that makes you HAPPY
OTA: AntennaCraft/RS VU-90XR (Attic Mt). DTVPal DVR, Sony RDR-VXD655, WinTV HVR-850-1200.
D/A: Samsung H260F, Winegard RC-DT09A, DTVPal Plus.
Typical OTA Reception Houston TX 77033
SWHouston is offline   Reply With Quote
Old 30-Sep-2010, 6:05 PM   #7
Tower Guy
Would you expect that will work for CBS on channel 8 at a distance of 72.4 miles without LOS?
Old 30-Sep-2010, 7:26 PM   #8
cw60
Smile
Thanks for all the good advise. I will put it to good use.
