Old 19-Aug-2012, 3:07 AM   #1
mv-free
mv-free's Avatar
West Michigan Lakeshore
TV Fool Report
http://www.tvfool.com/?option=com_wr...990057d515fe2a
I bought this antenna months ago to test the waters, had no clue about anything at the time (http://www.amazon.com/Eagle-Aspen-Dt.../dp/B000GIT002) Now I realize of course that is only UHF, and most of my channels are the VHF.
Pointing antenna SE from my location.
Currently:
13.1, 13.2 good to very good.
17's good at night
35's good.
Nothing below 13 at all.
I picked up an RCA pre-amp at menards, just to test (can easily return). That helped, but still nothing below 13...
I am interested in the networks Fox, NBC, CBS, ABC.
I am looking at an outside gable mount about 15ft or so up, pretty short cable run, maybe 35 feet total. (I'd like to do chimney mount...but a bit afraid of harming it)
I'd like the smallest, easiest antenna possible.
What pre-amp model? (Seems like Winegard are favored in this forum)
What antenna? CS5? Antennas Direct V21?
Would LOVE to hear suggestions... THANKS!
mv-free is offline   Reply With Quote
Old 19-Aug-2012, 8:44 AM   #2
Tv Reception.
A Teleview Recommendation for Tv Reception.
Above the roof install a Winegard HD7696P antenna with a Winegard AP8700 preamp aimed at about 125 degree magnetic compass direction.
Locate the antenna at a location that has the least amount or no amount of obstructions to the south east.
Old 19-Aug-2012, 8:51 AM   #3
Tv Reception.
For 2 Tv's connected use a HFS-2D , 2 way splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
http://www.hollandelectronics.com , or , http://www.solidsignal.com.
______________________
Old 19-Aug-2012, 8:59 AM   #4
Tv Reception.
All outside coax is suspect of being bad , replace with new RG-6 coax.
_____________________________________
Here is a way to prove reception.
Run a looong Known To Be Good coax from the HD7696P antenna through a open door or window , direct to the Tv , No splitters , No preamp , No nothing.
Antenna , coax , Tv.
What is reception now.
Old 19-Aug-2012, 2:00 PM   #5
mv-free
mv-free's Avatar
Great Info, thank you.
Thanks for the info... ordering items today! Can't wait to get it going
Another quick question:
I am going with the eave mount here:
http://www.solidsignal.com/pview.asp...u=610370579947
Mast, what is recommended to use?
Something like this?
http://www.3starinc.com/ez5-16_galva...od_16_awg.html
OR
http://www.solidsignal.com/pview.asp...-Mast-(TB-0005)
Thanks!
Old 19-Aug-2012, 4:25 PM   #6
Tv Reception.
Yes 16 AWG thick antenna mast is good to use. It is stronger.
Yes use the 4560 eave mount you have selected.
The bottom mounting bracket is extended out , and this will produce more distance between the top bracket and the bottom longer bracket.
This will make the mast more stable.
Old 19-Aug-2012, 4:31 PM   #7
mv-free
mv-free's Avatar
eave mount
Ronard
or
Winegard
http://www.solidsignal.com/pview.asp...u=615798313272
Big price difference, but if it is worth it I'll spend the extra $
Old 19-Aug-2012, 8:42 PM   #8
Tv Reception.
Your choice.
Old 25-Aug-2012, 6:35 PM   #9
mv-free
mv-free's Avatar
10 foot pole?
Okay, so early this morning I hooked this all up. Awesome! 33 channels came in, even a few from across Lake MI (Green Bay)! All the networks came in really good. 3, 8, 14, and 17.
As the day went on, I lost 17, and now 3, but yet channel 2 from across the lake still comes in.
I am wondering if my own house is getting in the way?, if you see the pictures. If I point at 125 degrees as suggested, it points right toward my 2nd floor.
Question 1: Is the exact degree crucial? If it is pointed slightly the other direction is that okay? Given these towers are a good distance away.
Question 2: I think if I went from 5 foot mast to 10 foot mast I would probably be able to shoot over my roof, but I am not sure if the mount is capable of a 10 foot mast... any ideas?
Or is it just the trees? I have to wait until fall...
Old 25-Aug-2012, 9:00 PM   #10
Tv Reception.
As always , the starting aim direction is the -> starting aim direction.
Your starting aim direction is 125 degree magnetic compass direction.
The antenna is then rotated to the left and right to find a aim direction that produces the best reception.
It looks the main situation with reception is the trees and tree leaves.
As always trees and tree leaves do a real fine job of reducing or blocking reception.
The antenna mount looks good and strong , I think a 10 foot mast will be Ok.
Here is a 10 foot tripod.
Put a mast pipe in that is 10 feet above the top of the 10 foot tripod and that will put the antenna 20 feet higher. http://www.ronard.com/Tripods%200703/4712.html.
In the fall and winter when the leaves fall off the trees . reception will be much improved.
Trees can also have the tops cut off or cut the trees down.
Old 26-Aug-2012, 12:33 AM   #11
mv-free
mv-free's Avatar
thanks
Thanks...
So if trees/leaves are the major problem, then adding 5 feet probably wont' fix it right?
Fall and winter is really only time I need TV anyway... all I need it for is for sports... mainly football.
Old 26-Aug-2012, 10:49 PM   #12
mv-free
mv-free's Avatar
Okay playing around today, trying to get ch 17 in better, I hauled out my old video 10 db 4 way booster I've had from way back, and hooked up right before the TV input.
To my surprise, 17 now came in without interruption, but quality dropped on many other stations... is this normal? How can I deal with this effectively? (an A/B switch to turn the booster on or off?)
Any suggestions?
Should I put this farther back on my line? My total run from antenna to TV is probably around 80 feet...
Antenna to pre-amp (3 feet).
Preamp to basement (45 feet).
Basement contains pre-amp power injector splitter.
30 feet from pre-amp injector splitter to wall-jack.
6 feet from wall-jack to TV set.
So around 84 feet from antenna to a single TV only.
These runs aren't too long are they?
Some of the cables I can shorten in total by probably 20 feet by chopping/replacing oversize cables...(if it will make a difference)
Old 27-Aug-2012, 3:10 AM   #13
Tv Reception.
The following is a Teleview Recommendation for Tv Reception.
Is a HFS splitter being used??
The preamp power supply and power injector is connected what connection of the splitter , input connection or output connection??
Old 27-Aug-2012, 3:13 AM   #14
mv-free
mv-free's Avatar
There is no splitter. When I say "splitter", I just mean the winegard injector. (kind of looks like a splitter)
Old 27-Aug-2012, 4:01 AM   #15
Tv Reception.
My concern is coax and connections being the real problem , however if the little distribution amplifier provides reliable reception on the channels go ahead and use it.
Yes you can try it at one end of the coax or the other.
If the other channels are also steady then no need to switch it in and out.
All amplifiers add electronic noise to the signal.
Old 27-Aug-2012, 4:15 AM   #16
mv-free
mv-free's Avatar
Yes
All the cable runs are new in the last year...
but, I am going to re-do the run from the basement to the TV jack, and see if that helps things... I just seem be getting such inconsistent results...
Again, thanks so much for the help.
Old 27-Aug-2012, 4:21 AM   #17
Tv Reception.
Movement of trees in the directions of reception will also effect reception.
Old 28-Aug-2012, 2:05 AM   #18
mv-free
mv-free's Avatar
Ham Radio
One other item I did not think of before that could explain some of the inconsistencies...
My next-door neighbor has some serious HAM radio equipment with very large antenna's strung up.
This whole setup is 50 or so feet from my antenna.. wondering if when he turns on the equipment if that is causing interference..
Old 28-Aug-2012, 3:49 AM   #19
There's a chance that may be the case. If so, the majority of HAMs are inclined to be helpful. Hopefully, you and your neighbor are already on good terms.
Old 28-Aug-2012, 5:13 PM   #20
mv-free
mv-free's Avatar
High Pass Filter
Would something like this help? If so... where is the best place to install it in the line?
http://www.solidsignal.com/pview.asp...-Loss-(HPF54HR)
