Old 23-Dec-2011, 4:26 PM   #1
tripelo
WDKY-DT Lexington, KY (no Omni Antenna)
For WDKY-DT:
Currently TVfool listing seems to indicate an Omni-directional antenna for both 'Current' and 'Pending'.
Although WDKY has a CP for installation of an Omni antenna, it has not done so.
WDKY is still utilizing their 'directional' antenna.
This information has been confirmed by a WDKY technical representative.
Old 9-Jan-2012, 12:14 PM   #2
tripelo
This is a link to the STA engineering data showing the current directional pattern for WDKY:
https://licensing.fcc.gov/cdbs/CDBS_...um=1&exhcnum=2
Old 13-Jan-2012, 2:00 PM   #3
tripelo
WDKY Antenna Pattern
Since the FCC site has removed the STA: BDSTA‑20090610ABF
A copy of the original FCC PDF is too large for attachment. Below are:
- Image of antenna pattern, as shown in the STA
- Excel file with field pattern values.
Antenna Pattern Field Values.xls
An extension was filed:
The extension appears to have the same information as the original STA.
Old 6-Feb-2012, 3:46 PM   #4
tripelo
WDKY - Virtual Channel 56
If changes are made to WDKY listing:
Consider adding virtual channel 56, as mentioned in January, 2011:
http://forum.tvfool.com/showpost.php?p=5140&postcount=1
