Old 19-Dec-2011, 12:02 AM   #1
bigdaddybama
Antennas Direct DB8 or Antennas Direct ClearStream4 or ?
Hello,
Here is my location http://www.tvfool.com/?option=com_wr...40331bcb3da728
I installed a ClearSteam2 and could only receive channel 15. I am going to return and am looking at these other two antennas. What do ya'll think?
Thanks in advance for your help,
Mark
bigdaddybama is offline   Reply With Quote
Old 19-Dec-2011, 12:49 AM   #2
MisterMe
You purchased a UHF-only antenna for an area with weak signals broadcast on a mixture of VHF and UHF channels. You receive WRBL because it is your strongest signal, it is UHF, and has no co-channel interference. At very least, you should get Antenna Direct's VHF dipole to convert your antenna to the C2v.
Old 19-Dec-2011, 3:01 AM   #3
Tv Reception with Tv antennas
How many tv's are/will be connected??
Old 19-Dec-2011, 6:18 AM   #4
My first impression of your TV Fool report is that I want to see TV Fool reports for 25 & 50 feet.
If this is the signal available to you, you'll need a large deep fringe antenna system.
Electron is right to ask how many sets are going to be connected. The answer drives recommendations re. rotator and amplifier options.
Old 19-Dec-2011, 11:52 AM   #5
bigdaddybama
Thanks for the replys. I only have one tv. I will run the report with 20 ft as this is the highest i can go.
Thanks,
Mark
