Old 28-Oct-2011, 5:27 PM   #1
mmathedrader
Question Looking for an antenna recommendation
http://www.tvfool.com/?option=com_wr...60b516cc7b448f
We currently clearly get CBC-4, CTV-13, CTV2 (A Channel)-43, CHCH (Ind)-11, SRC-9, TVO-24, and a couple of other channels that we don't care about. We also get analogue CBC on channel 36 from a town about 200km away. We get these channels with a set up of a TV top antenna about 15 ft above ground surface on the south side of the house connected to a home made hanger/wood antenna in a second story window facing north. We loose CTV and CTV2 if we disconnect the second antenna.
Would love to get CBS and PBS.
We are looking for a recommendation on a rooftop antenna. If it makes a difference, we live in Kanata, ON (Ottawa suburbs).
Help would be appreciated!
mmathedrader is offline   Reply With Quote
Old 2-Nov-2011, 12:11 AM   #2
To see WWNY-CBS, real; channel 7, will require at least a Winegard YA-1713 or Antennacraft Y-10713. In fact you may need a matched pair, stacked for additional gain. http://forum.tvfool.com/showthread.php?t=1024
WNPI-PBS, real channel 23, will require a big antenna such as the Antennas Direct XG-91.
Most amplifiers will be overloaded if you aim either of those antennas at the local stations but I think you'll need a preamp such as the Antennas Direct CPA-19 for the weak signals from the south.
This means you may want to install a smaller antenna for the local signals and then use an A/B switch to select the US antenna system.
Old 2-Nov-2011, 12:06 PM   #3
mmathedrader
Thank you. Most helpful!
Tags
antenna, recommendations
