Old 28-May-2011, 6:38 AM   #1
delsol
Antenna suggestion for Lincoln NE
Need some advice on what to purchase for a OTA setup.
http://www.tvfool.com/?option=com_wr...57478b2eea7505
Thanks
delsol is offline   Reply With Quote
Old 29-May-2011, 9:21 AM   #2
TV Antennas and Reception
Is this a , warehouse , shop , house , condo , apt. , mobile home , motor home , etc. . How many Tv's will be connected?? Does the building have any upper floors?? Does the building have any metal on the inside or outside of the walls?? Does the building have a metal roof?? Are the walls made of poured concrete?? Does the building have brick from ground to roof. How many Tv's will be connected??
Old 29-May-2011, 12:34 PM   #3
Thanks
I'd consider a Winegard HD 7696P with a moderate gain preamp, either the HDP-269 or AP 8700. I'd aim it at 37 degrees. You'd get a full compliment of networks without a rotor.
Old 29-May-2011, 6:04 PM   #4
delsol
Brick single story house with asphalt shingles. I will mount the antenna on the roof and hookup to 2 TV's
The Wineguard 7696p looks good what do you think of the xg91
Thanks
Old 29-May-2011, 6:16 PM   #5
Thanks
The 91 XG is a fine UHF only antenna that is not right for you. KOLN and KUON are on VHF frequencies.
If you want to pick up the LPTV stations at 340 degrees you could use a smaller cheaper DB-2 UHF only antenna. I did not investigate if all the networks have LPTV stations in that direction.
Old 29-May-2011, 9:39 PM   #6
I googled , K18CD 18 , KWAZ-LP 35 , K27GX 26 and these stations are said to be not transmitting. . KFLX-TV 51 is said to be transmitting as a FOX affiliate. You have FOX KPTM-DT UHF 43 at 45 degree magnetic compass. I also recommend a Winegard HD7696P antenna with a HDP-269 preamp. point the antenna at about 37 degree magnetic compass. Here is how to point Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html
Old 29-May-2011, 9:43 PM   #7
Here are places to buy Tv antennas and etc.. , http://www.solidsignal.com , http://www.3starinc.com , http://www.starkelectronic.com , http://www.amazon.com. Here are some free tv guides , http://television.aol.com , http://www.zap2it.com , http://tv.yahoo.com , http://tventertainment.excite.com , http://www.titantv.com , http://tvzap.com . Read and understand about , REAL Digital Broadcast Tv Channels , Virtual Digital Broadcast Tv Channele , Analog Broadcast Tv Channels , http://forum.tvfool.com/showthread.php?t=695
