Old 19-Mar-2022, 6:10 PM   #1
DaveBB
Replacing Old Antenna
I'm starting to lose channels slowly and was wondering if it could be the antenna. It's 9 years old. Looking for a replacement. https://www.tvfool.com/?option=com_w...b0febba265de5c
DaveBB is offline   Reply With Quote
Old 21-Mar-2022, 1:37 AM   #2
Tim
It could be the antenna if you have missing or broken elements or corrosion. But it is more likely to be:
  1. Coax connectors
  2. Grounding block
  3. Coax cable
  4. Balun
Old 29-Mar-2022, 6:40 PM   #3
rickbb
Slow loss of channels over time indicates corrosion of the connections or the balun.
Which does not rule out the antenna, it has connections too.
