Old 25-May-2021, 8:08 PM   #1
deeciple
Radio Shack attenuator (any good)?
Hi all,
I was going through some old electronics that I have accumulated and discovered (new in the package) a Radio Shack 20db variable attenuator (item number 15-578). I am currently using a 6db inline attenuator but I was wondering if anyone has had any experience with the 15-578 and can tell me whether it's any good or if it will hurt more than help. I like the idea of being able to adjust the level of attenuation but not if it will introduce much noise into the system.
Thanks,
Ken
deeciple is offline   Reply With Quote
Old 25-May-2021, 10:43 PM   #2
OTAFAN
Hi deeciple:
I have one of those and have used it in the past with expected results, from min to max. I can't remember what specs or numbers I was receiving, though.
I'm not using it currently so I can't report any present feedback. But since you did stabilize the signal to your receiver with a 6db attenuator as mentioned in your prior post, this might give you a bit more flexibility. Give it a try.
Let the forum know what results you get. I'm sure it would be helpful for some.
Thanks and all the best.....
Old 31-May-2021, 4:28 AM   #3
deeciple
Finally had a few minutes to connect up the variable attenuator. This past couple of days was very windy around here and with all the trees, not a good reception day overall
Once the wind died down I was able to test. I like being able to dial up the signal level to 100% and then back off just a tad but I don't see where I am getting any change in signal quality. I will keep it inline as I like the control it gives me.
Best regards,
Ken
