Old 11-Feb-2017, 4:19 PM   #1
ldh
Antenna Recommendations in Luray, VA
Hello,
I am looking to purchase a TV antenna for my house and was curious about what might be a good antenna for my area. Also, what type of equipment may improve my experience as well.
http://www.tvfool.com/?option=com_wr...e6a4e8651754a4
Thanks,
Luke
ldh is offline   Reply With Quote
Old 11-Feb-2017, 6:46 PM   #2
Luke,
Slim pickings.
How motivated are you? This will not be easy and the results will not be particularly predictable.
Old 11-Feb-2017, 7:02 PM   #3
Welcome, Luke:
Right, slim pickings, and in different directions.
WHSV will give you ABC, CBS, MyN, and Me-TV
http://www.rabbitears.info/market.ph...&callsign=whsv
W30CT will give you NBC and CW
http://www.rabbitears.info/market.ph...callsign=w30ct
WSVF will give you Fox and CBS
http://www.rabbitears.info/market.ph...&callsign=wsvf
PBS and ION will be a little more difficult.
I suggest a Winegard HD7694P antenna aimed at about 245 degrees magnetic to also add PBS on 21 or 11.
If ION is important to you, that would require a separate antenna aimed in a different direction.
As ADTech implied, this might require some experimentation; it's probably not going to work right out of the box.
What channels are most important to you?
Where will the antenna be located?
Are there any trees or buildings in the signal path from the SW?
Old 12-Feb-2017, 3:09 AM   #4
ldh
As long as I can get Fox, NBC, CBS, and ABC I am good. I have been away from my house most of the day and now it is to dark to see to the SW. As far as experimentation goes I love the challenge.
Old 12-Feb-2017, 3:57 PM   #5
Good.
