Old 26-Oct-2015, 5:38 PM   #1
tally
Suggest an Antenna
This is my signal analysis: http://www.tvfool.com/?option=com_wr...8e038a03d30b2b
Network channels appear real close - 9.9Miles.
What would be a good outdoor antenna for this situation.
Thank you.
tally is offline   Reply With Quote
Old 26-Oct-2015, 5:46 PM   #2
lets go red
With that sort of signal, some of your finer paper clips would suffice!
Realistically, an inexpensive old fashion, UNamplified, indoor bunny-ear/ loop combo is all you will likely require.
Unless you have serious multi-path or wire mesh siding an outdoor antenna might provide too much signal and cause overload. But I will digress to the experts on that...
lets go red is offline   Reply With Quote
Old 26-Oct-2015, 5:53 PM   #3
ANT-751 could work in the attic.
Old 26-Oct-2015, 6:25 PM   #4
tally
Ok that is great. I have used this antenna before on other installs. How about picking up some of the other channels with this setup in the attic (re: the ones about 18 miles away).
Thanks for the responses.
Old 26-Oct-2015, 6:33 PM   #5
lets go red
I would aim for the farther away stations with the ANT-751 as the stations out of Shoreview will probably be received no matter what azimuth the antenna is facing (in the attic).
