Old 31-Dec-2014, 6:58 AM   #1
Midlot
Antenna suggestion for central Indiana
Hi,
I am fed up with Comcast [they raised my bill $52 today] and want to put up an antenna. I would like to get ABC, NBC, CBS, CW, WFYI and FOX. I am only using one TV.
Here is the link to my TV signal Analysis;
http://www.tvfool.com/?option=com_wr...2c15497dda7f1b
What kind of antenna would I need? Would any of the indoor antenna's that you hang on the wall or window work?
Thanks!
Midlot is offline   Reply With Quote
Old 31-Dec-2014, 12:19 PM   #2
Probably unreliably. At 30 miles, indoors, and with a 2-edge signal path, you don't have much margin for success. If you have trees and/or neighboring homes in the signal path, your margin for stable, reliable reception plummets as clutter loss in the signal path increases.
The numbers say that a small high VHF/UHF combo is needed, probably attic or outdoors. The currently unknown variable is the previously mentioned possible clutter loss about which we know nothing. If you have an open field in that direction, reception will be easy. If you're looking into trees or your neighbor's house, not so much.
Old 31-Dec-2014, 2:33 PM   #3
Midlot
Thanks,
I have some large trees between myself and the direction of the towers [South West] that are about 50 yards from my home.
