Old 31-May-2014, 1:28 AM   #1
ds514
Question Setup advice for Sask, Canada
I'm looking for some advice on setting up an antenna. Here's my info.
I would definitely want to receive CBKT and CKCK would be very nice to have. I don't care about anything below that. The street is lined on the north side with mature elms.
A few questions:
1) Could I get away with an attic installation (~10 ft high)? The signal strength (yellow) suggests that I can, but I'm more in the cyan-blue range on the map.
2) Which antennas would be best? I'd be willing to go with a VHF only model, but one with UHF might be nice when I move if I choose to take it with me.
3) Does anyone know where to buy a good antenna in Canada?
Thanks!
ds514 is offline   Reply With Quote
Old 31-May-2014, 3:37 AM   #2
I recommend a VHF only antenna at your current location.
--->Above the Peak of the Roof<---> install a ,
http://www.antennacraft.net.
Y10-7-13 VHF antenna aimed at about 71 degree magnetic compass direction.
Here is how aim to antenna , http://www.kyes.com/antenna/pointing/pointing.html.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone , tablet or etc. compass.
A antenna system amplifier will most likely not be required for , 1 , 2 , 3 , Tv's connected.
With the Y10-7-13 antenna installed above the roof clear of obstructions.
http://www.tdlcanada.ca.
http://www.saveandreplay.com.
Last edited by teleview; 5-Jun-2014 at 12:07 AM. Reason: Clarify information and typos.
Old 2-Jun-2014, 9:11 PM   #3
ds514
Thanks for the advice. What do you think my chances would be with a Y5713 in the attic, outside, or a Y10713 in the attic? I'm not thrilled with the idea of having a 10' long antenna on my roof..
Old 2-Jun-2014, 9:55 PM   #4
Hiding any type or kind of Tv antennas in weak signal strength reception zones is a good way to have less reception.
The -->Only Way<-- to discover reception and the reliability of reception in the attic is to install the antenna in the attic.
Not being thrilled about large Tv antennas and not installing a large antenna in a weak signal strength reception zone that also has 2 Edge Path Obstructions=Hills and Mountains , is a good way to have less reception.
As always you are free to choose any antenna and install the antenna at any location you choose.
Old 4-Jun-2014, 2:01 PM   #5
ds514
Thanks for your time.
Old 4-Jun-2014, 3:42 PM   #6
Either antenna in the attic is likely to cause problems.
A Y5-7-13 on the roof should work fine but you may need a preamp.
Old 16-Aug-2014, 9:50 PM   #7
ds514
Update for the archive. I ordered a y10713 from tdl canada along with a channelmaster balun. The antenna arrived promptly but the balun took several weeks.
I put the antenna up in the attic, resting on the insulation and hooked it up to 25' of rg6. I picked up 9 and 11 beautifully, and 8 is almost always good. 7 (analogue) is grainy but watchable so I'll probably just use that as a backup to 8 since it's the same feed. I might also mount the antenna to see if I get 8 more reliably, but overall I'm happy with the results. No luck on 13, but since it's a French channel, I don't mind.
Overall I would recommend trying an attic installation of a y10713 to someone in Moose Jaw to get the Regina channels.
Old 16-Aug-2014, 11:01 PM   #8
To stabilize and clear the reception.
http://www.ronard.com/909911.html. Install the , ronard)911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 feet 4 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast pipe.
Here is a way receive All of the USA , PBS Networks for Free and also other Tv Networks for Free.
FTA-ST = Free To Air Satellite Tv , aka , FTA.
Received with a Small Dish. KU-Band , Small Satellite Dish.
And a receiver.
Here are places to learn more.
http://www.ftalist.com.
http://www.manhattan-digital.net.
I am curious , did you order and receive the Y10-7-13 antenna and other
components directly from TDL??
Or did the products come from one of TDL's , distributor/retail business sellers?? And if so which ones??
Last edited by teleview; 17-Aug-2014 at 8:59 AM. Reason: Clarify information and typos.
Old 17-Aug-2014, 2:53 AM   #9
ds514
I got them directly from tdl. They normally only deal with retailers, but since they didn't have any in my area, they sold directly to me.
Old 17-Aug-2014, 3:22 AM   #10
Very good , Thank you.
TDL has a lot of electronics and a lot electronics that are hard to find , all in one place.
When I contact TDL , I always tell them to sell directly to the general public.
I read reports of shortages of the CM94444 outdoor matching transformer in Canada due to the increasing numbers of people that are going OTA Over The Air , Broadcast Tv.
Last edited by teleview; 17-Aug-2014 at 9:00 PM. Reason: Clarify information and typos.
