Go Back   TV Fool > Over The Air Services > Special Topics
Old 16-Jun-2014, 12:56 PM   #1
astorie
Problem with trees?
Good Day:
I am new to this but am very happy for this forum. I am considering cutting my cable and have looked into the Channel Master ant. My concern is wondering if there will be an issue with trees in the way to assure that the signal strength is what everyone is saying this system would receive.
Appreciate your feedback.
Thanks
Al
astorie is offline   Reply With Quote
Old 19-Jun-2014, 11:50 PM   #2
Welcome to the forum.
Trees can be a problem, especially for UHF.
What does your tvfool report look like? It does not take into consideration trees. What direction are you worried about with trees?
Only testing will tell you if they are a problem at your location.
Old 20-Jun-2014, 3:35 AM   #3
Pete Higgins
Pete Higgins's Avatar
rabbit73,
Did you take an extended vacation?
Great to see you back posting -missed your posts.
Pete
astorie,
If you can post a link to an accurate TV Fool report for your address the experts can better assist you. It won’t reveal your actual address when others use it.
One last thought, if you have access to a computer, bring up your address in Google Earth and using the <Tools, Ruler, Line Tab> draw a line from your house along the degrees TRUE indicated for the stations of interest. That may help you pick an unobstructed antenna location to minimize degradation from trees and other nearby obstructions. TV Fool lists bearings in both TRUE & Magnetic so make sure you pick from the column labeled TRUE because thats what Google Earth uses.
Old 20-Jun-2014, 5:52 AM   #4
Hey Pete...
It's good to see both of you on the forum!
