Old 26-Feb-2014, 8:16 PM   #1
jeffg
South San Jose, CA...Need some help
Hello All,
Need some help from the experts. Here is my assessment.
http://www.tvfool.com/?option=com_wr...5b94d1d62ecfa0
I currently have a what appears to be an all band UHF/VHF/FM antenna ~ 18ft above GL. It was on the house when I bought it. I can rotate the antenna anywhere from 290-360* and pull in 11-1 (NBC) full power. I can also pull in 7-1 intermittently (strong signal in the morning, broken signal in the evening) but that is about it. I have a roughly 50ft coax connection to the TV.
I tried a Clearsteam 4. It too pulled in 11-1 but not 7-1, or anything else for that matter. Any suggestion? I think I am in a pretty bad spot. Tall homes and trees down my LOS.
Thanks
jeffg is offline   Reply With Quote
Old 26-Feb-2014, 11:57 PM   #2
Did you set your TV off of the "Cable" setting and on to the "Antenna" setting before scanning?
Old 27-Feb-2014, 12:09 AM   #3
jeffg
Wow, it physically hurts me to admit this but I just did eaxctly what you said, and it pulled down many more stations. I had thought I changed that. Thank you very much for the response.
