Old 8-Jul-2013, 9:50 PM   #1
anil_robo
Unhappy Batesville (Arkansas) reception help needed
Just moved in to this "No Man's Land", and TVFool's coverage map shows I should have at least two free OTA channels. I use Mohu Leaf antenna (which of course was working perfect in Manhattan) which is unable to pick up any channels here. Is it just a matter of buying a better antenna to get those two channels?
Here is my reception map: http://www.tvfool.com/?option=com_wr...0559962653ba26
Any help will be appreciated. Thanks.
anil_robo is offline   Reply With Quote
Old 9-Jul-2013, 7:00 AM   #2
Is this a , house , town home , condo , apartment , travel trailer , motor home , mobile home , or etc. ??
What directions do , windows , patios , balconies , face ??
What floor??
What is the top floor??
The provided tvfool radar map plot and channel list is the default 10 feet antenna height above ground.
To see what Tv reception signal strengths are at higher antenna heights please make and post 2 more tvfool radar map plot and channel list reports.
25 feet and 40 feet antenna heights above ground.
Old 13-Jul-2013, 1:08 AM   #3
anil_robo
Thanks for the reply!
This is a town house styled apartment with two floors. I occupy both floors.
Currently the TV is placed in the living room on first floor. The Mohu leaf antenna is also on the same floor, about six feet from TV, stuck to the north wall.
The window in the living room, where the TV and antenna is, is facing West. The patio door is 8 feet from TV, facing North.
Top floor is second floor.
I do not want to relocate the TV to second floor, TV must stay in the living room on first floor.
25 feet signal report: http://www.tvfool.com/?option=com_wr...46aef75610839b
40 feet signal report: http://www.tvfool.com/?option=com_wr...46ae24094130ad
Old 13-Jul-2013, 1:39 AM   #4
The first tvfool radar report is West of Jonesboro Arkansas.
The second a third tvfool radar reports are east of Little Rock.
Please make all the tvfool reports at the correct address.
Old 15-Jul-2013, 12:04 AM   #5
anil_robo
Sorry the latitude and longitude data confused me. I fixed them up.
Zero feet: http://www.tvfool.com/?option=com_wr...46ae282c8fdf90
25 Feet: http://www.tvfool.com/?option=com_wr...46aec66d605962
40 Feet: http://www.tvfool.com/?option=com_wr...46aee659526879
Old 15-Jul-2013, 2:11 AM   #6
Not much currently receivable for , OTA=Over The Air , Digital Broadcast Tv reception , Batesville.
KAIT , VHF high band channel 8 , ABC. To the East.
KEMV , VHF high band channel 13 , PBS. To the West
KTEL , UHF band channel 20 , PBS. Same PBS as KEMV.
You can try the , Mohu Least , on the second floor , with the flat sides aimed East and West.
Run a coax down to the first floor and connect to the Tv.
Go into the Digital Tv Setup Menu select and Scan for Digital Broadcast Tv stations/channels.
Not cable tv channels.
_______
ABC and PBS and 1 more Digital Broadcast Tv station/channel can be received , KVTJ UHF channel 48 , Religion.
A large antenna , Winegard HD7698P antenna will be installed on the roof and aimed at about 100 degree magnetic compass direction.
________________________
Up at Higher elevations , the hills and mountains , around Batesville , more Digital Broadcast Tv stations/channels can be received.
__________________________
Being that this is a Apartment.
Looks like your options are.
Streaming Internet ,
I recommend the http://www.roku.com , Box for the reception of , NetFlix , Hulu+ and etc.
______________
Teleco's - Phone companies , are beginning to offer streaming packages of services using a Box provided by the Teleco.
______________
And can go to individual web sites to receive programing.
_______________________________
Cable Tv service.
______________
There is , Dish Network and DirectTv.
______________
And another option , FTA = Free to Air Satellite Tv , A place to find out more , http://www.ftalist.com.
__________________________________
And can move to a City/Area where there are more receivable Digital Broadcast Tv stations/channels.
