Old 4-Mar-2013, 6:35 PM   #1
mdr76
noob looking for advice
noob here. looking any input on what devices i might want to get to receive some over the air HD. here is a link to my info:
http://www.tvfool.com/?option=com_wr...1ddae44223e1ee
mostly interested in NBC, CBS, and FOX. I'll most likely have a total of 4 TVs connected in the house. Any advice or links is much appreciated!
mdr76 is offline   Reply With Quote
Old 5-Mar-2013, 7:04 AM   #2
Above the Peak of the roof install a Winegard HD7000R antenna aimed at about 110 degree magnetic compass direction.
The receivable Group of Digital Broadcast Tv stations/channels are to the , south east
And the receivable WETP-DT Real UHF Digital Tv channel 41 , virtual number (2.1) PBS , to the south west and will most likely be received at the back angle to the HD7000R antenna.
A Winegard DS3000 J type antenna mount will work to mount the antenna on.
Install a Channel Master CM3414 distribution amplifier.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
______________________
As always , trees and tree leave do a good job of , multipath/reflecting , absorbing , blocking , OTA=Over The Air , Digital Broadcast Tv stations/channels reception and so do buildings and other obstructions including your own roof and house.
It is best install the HD7000R antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv station/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
Tags
antenna choice, noob
