Old 18-Nov-2012, 6:58 AM   #1
frustrated
Question Do I need an external antenna here in Canada?
I did the following analysis http://www.tvfool.com/?option=com_wr...cc496f95067da3 but am a bit puzzled with it as I can see where the Background color that it is referring to is.
Is it telling me I need an attic anntena or even an external one to get the basic Canadian network feeds like CBC, CTV, GlobalTV etc?
frustrated is offline   Reply With Quote
Old 18-Nov-2012, 8:58 AM   #2
For reception of the Canada Digital Tv stations/channels.
So , is this a , house , town home , condo , apartment , mobile home , motor home , or etc.??
What directions are the , windows , patios , balconies??
What floor??
What is the top floor??
If the building is wood with wood or vinyl siding and composition shingles is best for indoor reception.
For a indoor type antenna at each Tv location.
I recommend try a TERK HDTVi antenna , (not the HDTVa antenna) , aimed at about 215 degree magnetic compass direction.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
The following is a - non complete - list of situations that will reduce or block reception with a indoor antenna.
If the building is , concrete , brick , metal siding , metal backed insulation , metal roof , solar panels.
____________
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions or reception.
At your location that is , north , west , south.
Do Not channel scan for cable tv channels.
_________________________________________________________________
If Weaker Tv station CHMI-DT REAL VHF 13 , City Tv , is not received with the indoor antenna then install a ANT751 antenna , no preamplifier , above the roof in such a manner that the roof or building is not blocking reception in directions of , north west , south.
Aim the ANT751 at about 215 degree magnetic compass direction.
For 3 Tv's connected use a common simple 3 way splitter.
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com ,http://www.solidsignal.com , http://www.amazon.com.
