Old 15-Sep-2012, 9:32 PM   #1
floridaron
Talking Newbe anetnna help
I am in area zip32137
http://www.tvfool.com/?option=com_wr...5ed696e4876404
I am lost as to how I should pick an antenna etc.
Looking at the... http://www.solidsignal.com/pview.asp...pr-header-91XG
And the... http://www.solidsignal.com/pview.asp...a-%28CM5020%29
We are 65 miles from Jax FL and about the same from Orlando.
I can roof mount at about 32-35'.
I have a Drop amp EDA 2462 [5-42 54-1000 mhz 6kv 15vdc]
And my direct tv satellite cable pre-installed in the house.
I want to hook up 2 tv sets.
Thought I would buy an "Eagle Aspen ROTR100" rotor.
Lost in Florida, thanks Floridaron
floridaron is offline   Reply With Quote
Old 15-Sep-2012, 10:38 PM   #2
The following is a Teleview recommendation for broadcast tv reception.
Antenna system number 1.
For the Deltona/Orlando groups of Digital Tv stations/channels install a Winegard HD7698P antenna with a Antennas Direct CPA-19 Preamp , aimed at about 190 degree magnetic compass direction.
Here are places to buy the HFS splitters. http://www.hollandelectronics.com , http://www.solidsignal.com.
If you have a way to mount the antenna then Ok , if not then here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods5200703/4712.html , http://www.ronard.com/34424560.html , http://www.ronard.com.
It is best to locate the Tv antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
The Tv/s Must Channel Scan for Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or ' Antenna Channels' in the Tv setup menu because the Tv transmissions travel from the transmitting antenna to the receiving antenna.
Do not channel scan for cable tv channels.
Old 15-Sep-2012, 11:30 PM   #3
The following is a Teleview recommendation for broadcast Tv reception.
Antenna system number 2.
Aim a Winegard HD 7698P antenna with a Antennas Direct CPA-19 preamp , aimed at about 342 degree magnetic compass direction.
For 1 Tv connected use no splitter and no amplifier.
_________________________________________________________________
2 Separate antenna systems are Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing.
Antenna systems numbers 1 and 2 are not connected on to one coax.
The 2 antenna systems are Separate all the way to the locations of the Tv's.
The 2 Separate antenna systems are connected to a Remote control A/B coax antenna switch at each Tv location. http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425 .
A/B antenna switching is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing.
Is Ok to install 1 antenna system to begin with , Deltona/Orlango has many more Digital Tv stations/channels then Jacksonville.
Using a Antenna with a Rotator is Not Channel Surfing Friendly , must wait for antenna to rotate , and not every one in the house will agree on where the antenna is aimed.
Old 16-Sep-2012, 12:24 PM   #4
signals unlimited
Simple, effective DTV reception solutions
Install an Antennas Direct CS2 complete antenna with a Winegard AP8700 pre-amplifier and the Eagle Aspen rotor.
Follow the instructions with the rotor for a single coax configuration.
You will receive both of the markets that you desire and more.
Tags
antenna choice, mount, pre-amp
