Old 25-Aug-2012, 11:50 PM   #1
imjhemp
Dropping Pay TV
Hi guys..would like to get help figuring out which antenna is best for me.
Any help from the peeps that know what they are doing and talking about would be great. Thanks.
http://www.tvfool.com/?option=com_wr...e77919f27565d6
imjhemp is offline   Reply With Quote
Old 26-Aug-2012, 3:28 AM   #2
Tv Reception.
The following is a Teleview Recommendation for Tv Reception.
A Simple reception situation.
Above the roof install a Winegard HD7000R antenna with No preamplifier , aimed at about 22 degree magnetic compass direction.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
For 3 Tv's connected use a common simple 3 way splitter.
______________________
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best to install the antenna at a location that has the least amount or no amount of obstructions in the direction of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
