Old 1-Aug-2012, 2:11 AM   #1
mg42
antenna suggestions and ideas
just looking for input on antenna ideas, rural area, up on a hill, no trees or buildings, roof mount approx 20 to 25' up. Here is the report:http://www.tvfool.com/?option=com_wr...9900cf7fc7c381
looking for antenna ideas, rural area,up an a hill,roof mount, any and all ideas considered. here is my report:http://www.tvfool.com/?option=com_wr...9900cf7fc7c381
Last edited by GroundUrMast; 2-Aug-2012 at 1:35 AM. Reason: Merged multiple posts, moved to Help w Reception forum
mg42 is offline   Reply With Quote
Old 2-Aug-2012, 12:21 AM   #2
Tv Reception.
A simple reception situation.
Above the roof mount and aim a ANT751 antenna with a Antennas Direct CPA-19 preamp at about 206 degree magnetic compass.
As always the starting antenna aim direction is --> the starting aim direction.
206 is the starting aim direction , the aim direction is then adjusted for best reception.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
For 2 Tv's connected use a ,
HFS-2D , 2 way splitter.
For 3 Tv's connected use a ,
HFS-3D , 3 way splitter.
The HFS splitters pass power from the indoor power transformer/power injector to the actual preamplifier that is mounted close to the antenna outside.
http://www.hollandelectronics.com , also available at , http://www.solidsignal.com.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
