Fox in NYC is available as channel 5.1 in HD on UHF 44. It is also available in SD as 5.2 on UHF channel 38. Similarly, channel 9's programming is also available as sub-channels but on the opposite frequencies. If you're getting 9.1 and 5.2 but not 5.1 and 9.2, then you're missing the signal carried on channel 44.
Your new antenna is a very large one with a significant wind load. Don't be afraid to install guy wires, if needed to prevent it from coming down and damaging your eave in the process.
