Old 14-Apr-2011, 2:43 AM   #8
mrpep
A non-amplified set of rabbit ears will work.
The HD7964P and HBU-33 are both excellent, premium solution options.
An RCA ANT-751 is plenty of antenna.
The C5 is also an excellent product, but not a UHF design. With the signal levels at your location, it would likely work, but is not the best choice.
The first two suggestions, can recover enough signal to insure excellent signal levels after splitting the signal to as many as eight sets. The RCA can drive at least four.
Looks like NSAA and I are think similar thoughts.
Regardless of antenna choice, aim at about 110° per your compass.
Can I use the HD7964P in the attic? I kinda would rather cause I dont have to go on teh roof and I am not that far from my signal which I believe is the sears tower so attic antenna might get me all my stations. What do you think?
mrpep is offline   Reply With Quote
