Old 27-Feb-2020, 2:16 AM   #2
Tim
Originally Posted by mikmaze View Post
rsults are here: http://www.tvfool.com/?option=com_wr...9038762333d804
I am on a bit of a higher spot on my property, and would say my antenna is about 40 feet up. it is a big one from channel master, about 12 feet long. I run as short a coax as possible, ant is pointed towards most concentrated signals. Of course, I would like to get more reception. any good signal amps? should I go higher\? does not seem like I am that far from signal sources, but just not getting all that I think I should.
thanks for any and all help !
Wow! That's probably one of the worst signal reports I've seen posted. Which of the stations are you able to receive?
It would be helpful if you could also post a link to your RabbitEars signal report...there site is much more up-to-date than TV Fool.
