Old 11-Nov-2019, 1:32 PM   #2
JoeAZ
No easy solutions and lots of work involved....
For starters:
I would run a PROVEN "jumper cable" from each of
the antennas to a tv at the base of your tower. How
do each of the antennas perform compared to what
you are now typically receiving??? If better, then
you know the wiring/amplification is suspect further
down. I'd also try the above with/without amplification
as that FM station may be causing you some interference.
