Old 24-Jun-2018, 4:04 AM   #48
Dagwood
Dagwood's Avatar
Correct me if I am wrong, but I assume you know how to send a PM (a forum Private Message) to me, so you must mean how to determine the coordinates of your antenna.
If you don't have a GPS, you can use the TVFool Interactive map browser.
Once you have found your home, you can move the teardrop indicator to the location of the antenna by drag-and-drop. As you move the teardrop, the coordinates below the map will follow.
I just ran through it and now that I see it, I know I've done it before -- maybe last winter. At any rate, I will PM you the link.
Dagwood is offline   Reply With Quote
