Old 6-Jun-2017, 11:25 PM   #4
JoeAZ
Hi Billydee,
You do not mention if you are having any issues with any other
stations. If you are not, then the translator is the problem.
K42DI-D is a translator for KREZ DT which rebroadcasts
KRQE Albuquerque. Depending on your exact location, you
can receive KREZ directly from their broadcast point at Durango.
They operate on Rf15. You may wish to test by rotating your
antenna to point at Durango. You would need to perform a full
scan to see which stations you receive and which you do not.
Once you do that, let us know what you find......
You should also contact KRQE and let them know of your issues.
With all the cutbacks stations face, translators are NOT a
priority these days....
