Old 12-May-2017, 7:36 PM   #41
Originally Posted by Bigbear View Post
After reading other posts about poor reception, how much does being surrounded by trees contribute to my issue? There are lots of trees between me and Mt Mansfield.
It contributes a LOT to the problem; trees block TV signals.
http://www.hdtvprimer.com/ANTENNAS/siting.html
Scroll down to Trees and UHF.
I do see trees in your area, but I'm not sure which house belongs to you. I have removed the street names from the satellite image:
If you are willing, maybe you can give me the exact coordinates of your antenna in a PM so that I can see how the trees interfere with the WCAX signal. You can get the coordinates using the tvfool interactive map browser. As you move the cursor by drag-and-drop, the coordinates below the map will change.
I will not post a closeup of your house with the green signal lines without your permission.
A photo of what an antenna "sees" when it is aimed at WCAX would be helpful.
OK, WCAX doesn't do well with your present antenna aimed at 342 degrees true/356 degrees magnetic.
What we want to know is how does WCAX do with a UHF antenna like the DB2e or DB4e aimed at 112 degrees true/126 degrees magnetic.
