Old 10-Aug-2016, 6:40 PM   #14
rickbb
Originally Posted by crashHD View Post
The current antenna is on a rotor, at the top. If this DB8e gets solid reception of the west stations, I'm toying with the idea of fixing/replacing the rotor and putting a good UHF/VHF long range antenna back up there. I would leave it usually pointed to the east. There are two stations in the VHF Hi range to the east, the weakest one being about -8.3dB NM according to tvfool. I'm not trying to pull them in right now, but I think I would enjoy trying to see if I can pull them in after I've managed reliable reception of the UHF stations in the west.
The DB8e, (with reflector), has about the longest range, (gain) of almost all the other UHF antennas out there.
If you only want UHF from the west and VHF from the east, I'd put the DB8e on top aimed at your westerly stations and a VHF 4 feet below it aimed at your easterly stations then combine them with a UVSJ, or a pre-amp with a separate VHF/UHF inputs.
