Old 12-Jan-2016, 3:15 PM   #3
Tim
3) Replace the offending bulbs with incandescent bulbs.
I would go with some incandescent bulbs first and see if the problem still exists. There could always be something else on that same circuit that is causing the issue such as a loose connection somewhere, a bad switch or outlet, a bad doorbell transformer, a switching type power supply plugged into an outlet, an electric blanket or heating pad plugged into an outlet, etc.
