Old 11-Jan-2016, 9:35 PM   #5
Back in August 2015 , I thought I was going to have to do a jointenna with another antenna. Tower Guy suggested the Yagi antenna and the jointenna so I could get WLOS and the rest of the stations (CBS, FOX, NBC & PBS).
I see you have a previous thread. It would have been easier to help you if you had added to that thread instead of starting a new thread.
Your previous thread
Need your help with getting Channel 13 WLOS from attic antenna
http://forum.tvfool.com/showthread.php?t=14694
your previous report
http://www.tvfool.com/?option=com_wr...e1c62c5d9dda68
Your previous report looks different enough that I thought you moved.
He didn't say use it as your only antenna, he said add it as an additional antenna for WLOS, real channel 13, because it was in a different direction.
To try for WLOS in the attic get a Y10-7-13 plus a channel 13 jointenna from the Channelmaster store. Aim the antenna at 5 degrees and try it without your existing antenna. If it works, then combine the two antenna with the jointenna.
You need to add another antenna, with a UVSJ combiner, for UHF like a DB4e.
