Old 26-Dec-2015, 12:30 PM   #10
By the time I connected my system on 12/23 the roof was too icy to adjust the antenna.
Understood
With tree interference, is the best option to rotate/relocate the antenna until I get the best signal?
Try to relocate the antenna to avoid the trees as much as possible as ADTech said in post#4; trees block signals.
http://forum.tvfool.com/attachment.p...0&d=1448314548
Any preferred HLSJ manufacturers or locations/sites to by a HLSJ?
http://www.atvresearch.com/hlsjvhfba...-combiner.aspx
http://www.nsccom.com/browseproducts/HLSJ.HTML
http://www.nsccom.com/hlsj.aspx
Attenuator sources
variable
fixed
http://www.3starinc.com/drop_in-line_attenuator.html
http://mjsales.net/collections/atten...ant=1083705673
Attenuation values 1, 3, 6, 8, 10, 12, 16, 20dB (FAM)
click on 1 dB for other values; the up and down arrows are faint
