Old 9-Nov-2015, 1:30 PM   #30
agmccall
Originally Posted by StephanieS View Post
1. Test Winegard antenna at location where cheapie RCA antenna is. Remember with trees and weak signals you may be playing around with various locations to find sweet spot. Coax to one TV only for purposes of test.
Can't do that, the cheapie rca is mounted to side of house next to window
2. Give up on Utica completely. Albany is and remains your best bet as has been suggested to you.
3. If no success, get above tree line completely. This may mean a 40' mast anchored to the side of the house, or a tower that clears the tree line.
At the cost of such a tower I might as well just get a satellite dish and service.
TV antenna installation can be a bit of a black art. Each installation is different and obstructions can cause reception problems, both seen and unseen. Lesson: you have to keep testing if you don't have the desired results.
Thanks for your reply
al
agmccall is offline   Reply With Quote
