Old 4-Nov-2015, 12:56 AM   #6
SusanS
You can extend a cable with an F-81 adapter
I have found that out, thanks. I wasn't going to go to the trouble with the RCA, as it was an indoor model, and I knew it then it wasn't going to work.
What model? Do you have a link?
http://www.amazon.com/gp/product/B00...ilpage_o01_s00
the model is: 1byone® Amplified Outdoor Antenna - 50 Miles Range Outdoor Antenna for VHF&UHF with SMD Circuit Technology, Detachable Amplifier USB Power Supply
I think perhaps my wording was wrong. The outside juncture is grounded to the electrical box. Once the cable enters the home, it then goes to a splitter for the two televisions. Does that change what you wrote??
Does this change your thoughts on which antenna I should be looking at? Is it better to buy one built in, or on its own?
SusanS is offline   Reply With Quote
