Old 4-Jul-2015, 10:12 PM   #10
Hello, mg:
The AC9 is no longer available, the manufacturer Antennacraft folded.
http://www.antennacraft.net/Antennas...llChannel.html
It was designed to cover all three TV bands:
VHF-Low, real channels 2-6 (not virtual channels)
VHF-High, real channels 7-13
UHF, real channels 14-51
It is the real channel listed on your TVFOOL report that determines the antenna needed.
teleview picked that antenna because he saw some channels on your report that were in the 2-6 range, but I'm not convinced you need them. You could probably use a combo antenna for VHF-High/UHF. He also suggested to aim between the two major directions in hopes that you would pick up both, but that doesn't always work. You might have to make a choice to aim at 101 or 286 magnetic.
If both directions are important, you might need two antennas or a rotor with all its disadvantages.
I read someone referring to the "recommended antennas list" in this forum itself that I couldn't find, can I get the link please?
This is the list, but it is a little out of date. Stick with our current suggestions.
http://forum.tvfool.com/showthread.php?t=11
I think you should try the Winegard HD7694P or the RCA ANT751 aimed at 286 magnetic, no amplifier needed.
http://www.solidsignal.com/pview.asp...enna-(hd7694p)
http://www.skywalker.com/catalog/Manuals/WIN1051.pdf
http://www.solidsignal.com/pview.asp?p=ant751
I hope there are no trees in the signal path, they really mess with TV signals.
