Thanks for your quick reply, Ground. I know you are right about the rg59 but At my age I was hoping to avoid crawling the house with new cable, but it is probably best in the long run. theHD7015 is 111" wide so that would eliminate the garage attic install as trying to fit between the roof rafters at the proper azmith would be impossible. I would definately need to go outside.
I looked at the denny's antenna service HD Stacker antenna. Would you happen to know anything about it or something smaller that would work. I am assuming it is the channel 5 requirement that is the major problem?
Reason: typo
