Old 3-Nov-2014, 6:14 PM   #29
mulliganman
There are two possible reasons for the increase in uncorrected errors for 10:
1. Local electrical noise interference on VHF-hi, which has higher noise levels than UHF. If the noise is constant, then you should also see a reduced SNR. I have a fairly strong CH 10 signal, but its SNR is only 16 because I also have a high noise level on VHF-hi.
2. Multipath interference for the CH 10 signal. This could be from static reflections, or it could be dynamic multipath from moving objects, like vehicles or aircraft. A possible solution would be to use a more directional VHF-hi antenna to replace the V in the C2V. I think the C2V has an integrated UVSJ, so you might need an external UVSJ to combine the new VHF-hi antenna with the C2V.
IF the problem is multipath, and IF a more directional VHF-hi antenna helps, then another alternative would be to replace the C2V with a UHF/VHF-hi combo antenna.
Check out this theory with ADTech before doing anything drastic.
IIRC, the early TiVo tuners didn't handle multipath reflections very well.
https://www.google.com/?gws_rd=ssl#q=TiVo+tuner+doesn't+handle+multipath+very+well
You could test this theory in a low-cost way by connecting your antenna system (or just the C2V) directly to a TV and see if there was any difference.
OTA signals are constantly changing. If you want a real-time side-by-side comparison between two tuners, you can insert a splitter after the antenna system to feed the Roamio tuner and a TV, and feed a second TV connected directly to the splitter.
If something bad happens as shown on the TV connected to the Roamio tuner, you can see if it also happens to the TV connected directly to the splitter.
I forgot; where are your antennas located, inside or outside?
Yeah I want to hear from ADTech as well to see his thoughts. My antennas are roof mounted. There is no doubt inserting the Winegard LNA 100 to the 91XG line before that signal goes into the AC7 combiner improved things. I didn't expect it to raise the signal levels for all channels too....
I thought I remember reading that the Roamio had a pretty good tuner and was an improvement over the Premiere.....
I should also add I have noticed a small error number appear on 33-1 as well since implementing the changes ADTech suggested. But, it hasn't been as consistent as the 10-1 error number.
