Thread: Dropping DTV
Old 21-Dec-2010, 11:11 PM   #9
elmo
Originally Posted by okhomer View Post
If I do use a 2nd antenna would I need to run a 2nd line or use a spliter?
Yeah - was gonna say if the HDHR is the dual tuner type, you could try one antenna on each tuner. I tried that initially when I added a 2nd antenna. Then I got another HDHR so I can support two tuners on each antenna. But as long as you have two tuners, you can enable only the channels you want on each. I run WMC which will automatically tune to the tuner req'd for the channel I select.
