Old 15-Sep-2014, 10:04 PM   #13
OIIIOThing
Normally, the HBU-33 would work with that TVfool report. Yet, your reception isn't as good as tvfool reports. Add to that the 34 degree difference between your UHF stations. I'd consider a 4 bay UHF antenna. You have two VHF stations that you can try to receive. The HBU-33 would be aimed at WBTW. The 4 bay UHF would require a second VHF antenna Y5-7-13 aimed at WCTI.
If you opt for a second VHF antenna, switch the preamp to the dual input mode.
Double check that the FM trap is switched on in the preamp.
Thanks Tower Guy. I have actually been thinking of the 4bay type because I thought it might do better at pulling in the weaker signal but also be flexible to pull in frequncies from different directions. My biggest concern is just the "green" stations so anything beyond that would just be icing on the cake.
OIIIOThing is offline   Reply With Quote
