Old 15-Sep-2014, 6:28 PM   #11
Originally Posted by OIIIOThing View Post
The HBU33 was recommended...why that one vs another? I know its a good antenna but is there something specific I should be looking for?
Normally, the HBU-33 would work with that TVfool report. Yet, your reception isn't as good as tvfool reports. Add to that the 34 degree difference between your UHF stations. I'd consider a 4 bay UHF antenna. You have two VHF stations that you can try to receive. The HBU-33 would be aimed at WBTW. The 4 bay UHF would require a second VHF antenna Y5-7-13 aimed at WCTI.
If you opt for a second VHF antenna, switch the preamp to the dual input mode.
Double check that the FM trap is switched on in the preamp.
