Thread: TV Signal Issue
Old 19-Aug-2014, 10:43 PM   #5
To Prove Reception.
Remove the old matching transformer (balun) that is connected to the antenna.
Connect a NEW Channel Master CM94444 Matching transformer to the antenna.
Connect a NEW -->Continues Length<-- of Coax to the New Matching Transformer , and run the NEW Continues Length of Coax through a open door or window Direct to 1 Tv.
No couplers.
No splitters.
No amplifiers.
No nothing.
It is the , Antenna , NEW matching transformer , NEW Continues length coax , Direct to the 1 Tv.
Aim the antenna at about , 329 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Digital Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
The Tv Must Channel Scan for the , OTA=Over The Air , ATSC Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
DO NOT Channel Scan for Cable Tv Channels.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building , in the directions of reception.
The directions of reception at your reception location are , West North West , South West.
The Best Practice for Reliable Reception is to install the Tv antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building , in the directions of reception.
The directions of reception at your location are , West North West , South West.
What is reception like now??
