Old 1-Jun-2014, 8:56 PM   #8
Stereocraig
Originally Posted by gkbenji View Post
Okay, let me restate things. I don't care about TV (OTA or otherwise) enough to pay hundreds of dollars, but if there's a cheap fix (say less than $50) I'd spend a little.
I know OTA signals can be capricious... is that the only answer? Lucky bounce on channel 6? Still doesn't quite make sense to me... one channel perfectly clear, and not even a sniff of another one? If the only advice here is for buying and aiming antennas, that's okay. I was just hoping there might be something else simple I was missing.
I totally agree, OTA is not for everybody.
I suppose if you want to risk 50.00 to see if you can pick up more than one channel, you won't be out a lot, if it doesn't improve your results.
There's really not any one solution that fits everybody's needs.
I also agree w/ GUM, in that just by sheer coincidence, the lead in wire is capturing some signal and not the antenna itself.
