Thread: antenna advice
Old 16-May-2014, 11:46 PM   #3
The Tv signals are strong at your reception location.
The FreeVision should work Ok.
Aim the FreeVision antenna at about 270 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone or tablet compass.
Replace the matching transformer (balun) with a New outdoor matching transformer.
Connect a NEW Continues Length of Coax to the New matching transformer and run the New Continues Length of Coax through a open door or window direct to 1 Tv.
No antenna system amplifier. Disconnect and Remove All Parts of the amplifier , Disconnect and Remove the Preamp , Disconnect and Remove the Power Injector/Power Supply.
Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
Can also Test reception with a , http://www.antennacraft.net.
HBU33 antenna aimed at about 270 degree magnetic compass direction.
Use the same Test coax.
For a antenna system amplifier use a , http://www.antennacraft.net.
10G201 preamplifier.
With the Test coax.
What ever antenna is used , install the antenna Above The Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , West South West , West , North West , North East , East , South East.
