Old 15-Dec-2012, 3:56 PM   #5
Install a Winegard HD7696P antenna above the roof in such a manner that the roof and house are not blocking reception to the , west north west and north east.
Aim the HD7696P antenna at about 312 degree magnetic compass direction.
If WRPX-DT UHF channel 15 ION at 27 degree magnetic compass direction is not received and you will like to to receive , try adjusting the direction of the HD7696P antenna.
If still not received install the Channel Master antenna aimed at about 27 degree magnetic compass direction.
The 2 antennas Will Not be connected together on to the same coax.
The coaxes will be separate all the way to the location/s of the Tv/s and connect to a Remote control A/B antenna coax switch at each Tv/s location.
http://www.radioshack.com #15-1968 . or . http://www.mcmelectronics.com #32-4425 .
_______
As always , trees and tree leaves do a real fine job of reflecting or reducing or blocking Digital Tv reception and so do buildings and other obstructions including your own house.
It is best to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
________________________
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html if using eave mount , use the #4560 , http://www.ronard.com/ychim.html , http://www.ronard.com ,
http://www.ronard.com/tree_adjust.html.
Trees like to beat up antennas , if using the tree mount , cut tree branches away in such a manner that the branches can not whip around and bust up the antenna and are not reducing or blocking reception. Tall straight Pine trees work the best.
Falling out of a tree is very close to zero fun , so do not do it.
Or Buy from ronard.
