Old 14-Aug-2012, 11:32 PM   #2
Tv Reception.
The signal strength of the Tv transmissions are weak at your location.
Recommend Above the roof of the 2 story house install a Winegard HD8200U antenna with a Winegard AP8700 preamp , aimed at about 130 degree magnetic compass direction.
Here is how to aim antennas and etc. , http://www.kyes.com/antenna/pointing/pointing.html.
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
For 2 Tv's connected use a , HFS-2D 2 way splitter.
For 3 Tv's connected use a , HFS-3D 3 way splitter.
http://www.hollandelectronics.com , also at , http://www.solidsignal.com.
____________
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna,
