Thread: Reception help
Old 7-Jun-2012, 6:28 AM   #2
An amplifier should not be required...
The Mohu Leaf is not known for it's ability to receive VHF (Real channels 2 through 13).
If you can not or will not mount an antenna outdoors (where there's higher quality signal to be had), then consider the Terk HDTVi (not the HDTVa). The HDTVi is a modestly directional indoor antenna which has both UHF and VHF capability.
http://forum.tvfool.com/showthread.php?t=2828
A roof mounted Winegard HD7000R would be my choice. Aimed north as a starting point to see if I could get the Sutro Tower signals while also getting the San Jose stations.
