Old 7-Apr-2012, 6:42 AM   #18
Thanks for the update.
Virtual channel numbers are needed now that more than one program can be broadcast on the same RF channel, but the concept of a virtual channel provides the opportunity for much confusion. When selecting antennas, the virtual channel number is of no significance. Additionally, antennas have no awareness of analog vs. digital or HD vs. SD.
As you read your TVFR, it's important to distinguish between the real and virtual channel numbers. When I use the term UHF or VHF, I am always referring to the real channel. When deciding what type antenna is needed, focus on the real channel number, not the VC.
When setting up an antenna indoors, you may want to refer to the estimated dipole lengths posted here: http://forum.tvfool.com/showthread.php?t=2828 If you are having trouble with a particular real channel 2 through 13, selecting the optimum dipole length for the problem channel may make a significant difference.
