Thank you. I have 2, 12" drill bit extensions I'll try this weekend.
So then, based on what you tell me, it's okay to run the mast ground along side the coax in the attic, and then to the electric service? Won't the future lightning strike then enter the house by traveling thru the attic? Is this a better route than running a mast ground to a ground rod on the east end of the house where the antenna is mounted?
I appreciate the help you're feeding me! --gopokes
